Two submains from meter | Page 2 | on ElectriciansForums
Discuss Two submains from meter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Reply to Two submains from meter in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
