Two test leads, one port | Page 2 | on ElectriciansForums
Discuss Two test leads, one port in the UK Electrical Forum area at ElectriciansForums.net
Keighley
Hoping someone might be able to help. I’ve seen an ‘adaptor’ that allows 2 test leads to run from one port of an MFT (doing IR test). But, can’t find anywhere to buy it. Anyone know where I could get one from?
Do you mean like this?
[ElectriciansForums.net] Two test leads, one port
I'm a little confused by this thread to.
For an IR test where you are joining L and N, you are joining the L and N of the outgoing conductors not the test leads.
I can't understand why everyone is so confused. Sometimes you want to do some test or another from A + B to C. For an IR test that might be L+N to E, or L1 + L2 + L3 to E or whatever, which if you have stackable test leads, you can achieve by putting one clip on each conductor and stacking / piggybacking the leads if they are stackable. It reduces the number of things that might come apart or ping off during the test, vs jumpering with separate croc clip leads. In electronics lab work, joining, branching and daisy-chaining test leads is normal so most bench test leads have a piggyback socket.
I keep a set of touchproof stackable leads and probes in the testing kit to make up whatever configuration is required. They are only for dead tests though as they are not CAT III rated.
Ah, Lucien's post has helped. The wording of the question made me think the OP was trying to do some sort of different test by using both ports of the MFT.
Oh yeah, that's a good idea :D
I was always under the impression that if you individually test L to E, and N to E, without joining them together, you basically do the same test, just without the hassle of having to use piggyback leads or disconnect stuff?
Reply to Two test leads, one port in the UK Electrical Forum area at ElectriciansForums.net
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
