Two way light switch with a difference!!! | Page 2 | on ElectriciansForums
Discuss Two way light switch with a difference!!! in the UK Electrical Forum area at ElectriciansForums.net
kkkkk
I would be very interested to have everyone's comments on the safety aspects of this........
I have found a light switch in a commercial building which is wired up so that when it is in the "on" position, it switches a light on to be used in the day, but when it is in the "off" position it causes another light to be switched on to stay on all night (which is a low powered light). Therefore the switch is not an isolator, in either position there is a light switched on.
This has been wired this way intentionally.
Any comments?!!!
:90:
I've got a 2 way switch similarly wired at home.
One position the hall light is on, the other position a PIR outside is enabled which switches on the Hall light if activated.
Anyone coming towards the front door is met with the Hall light coming on.
Provided it's properly thought out and safe, there are a lot of "non standard" things you can do with electrics. For example, I have a flow switch in the water pipe to the shower. It triggers a timer which supplies the extractor fan. The fan then runs during a shower and for 30 minutes after, to clear the condensation. It's not one of the usual ways of controlling a fan, but it suits me and is perfectly safe.
Ha! That's great, strange way of doing it but well thought out...
Exactly my thoughts as above,cant see any problems with it,as long as both lights are on the same phase if not would require labelling of some sorts,would be a nice idea if the switch was etched showing what position of the switch did what but thats me being fussy.
Reply to Two way light switch with a difference!!! in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Ah yes my apologies, thank you much appreciated.
