Two way switch | Page 3 | on ElectriciansForums
Discuss Two way switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I only saw 3c&e at college until my 3rd year when the boss got it to speed up smokes and boilers lol
the conversion method is a good way to make a 1w into a 2w as you say, but to do it for them all I'm sitting thinking about how many wires would be at a 4g switch with 2x2ways at it lol would it need a double track to pipe them all to the box lol
Would that be a 4 gang at 1 position and a 2 gang at the other position?
Sorry Phil I'm confused, can you explain exactly what type of switching arrangement you are trying to achieve, the description given is a bit confusing.
oddest way i ever saw was loop in at light, then a 3c/e from light to each switch, so in the pendant were 2 1.5mm T/E and 2 3 core/E. right bloody squash.
I've used this method before - it was real handy because we couldn't get a twin and a 3-core down the existing (embedded) capping. 3-core down to each switch and do the terminations in the roof space where there was plenty of room. Granted though, we didn't terminate at the light fitting, it was done with wagos with only a twin dropping in to the light fitting. Horses for courses eh?
He's not trying to achieve it. He's simply pointing out that with such a setup the proper method of two-way switching makes far more sense than the conversion method with 400 cable cores at every switch position!
Personally I use both methods of wiring a two way, it just depends on what I judge to be the most efficient way for a particular job.
But then I also prefer the central joint box method of wiring lighting which is terribly old fashioned and out of vogue these days.
Sent from my iPad using Tapatalk
Sorry to be novice, what is notification?
my understanding was my mate does all wiring and then some one will check and signs it off(certify)
is notification to council?
If you are using some independent to certify the work it will have be checked at each stage of the installation not just at the end, for example the inspector will want to see were you have run the cables before you plaster over them , make sure you get somone in place before you start any work so they can explain their requierments as you cound end up with a situation were you can not get the installation signed off
Reply to Two way switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
Hello freddo (and everyone else who commented!), Thanks for your comment. Using that info, I now have this on the main: and this on the...
