Type 1 SPD and over head lines | on ElectriciansForums
Discuss Type 1 SPD and over head lines in the UK Electrical Forum area at ElectriciansForums.net
Welchyboy1
Nearly Esteemed
Essex
Hi all
i have just recently watched the NAPIT webinar on SPD’s and it says a Type 1 SPD device should be installed in premises supplied by overhead lines
I’m assuming including domestic properties
up to now I have only been using type 2’s in the consumer unit
is everyone fitting type 1 in this situation
and Is this in addition to a type 2 ? Didn’t really clarify this
thank you Westward10
It seems type 1 are not that easy to get hold of, type 2 are really common and most brands make them now but type 1 are not that readily available from looking around are they usually a special order rather than off the shelf?
Yes, been having this d*ck around recently as well, having to tell a customer their 5 year old CU is hopelessly out of date because 63A type AC RCDs no SPD etc managed to get them to agree to RCD swapout and Type 2 SPD but the type 1 was the straw that broke the camels back..! No option to fit into CU (Hager) and a standalone unit was going to be £400 fitted (at least) so a flat 'No' there. Best option I found to offer was a Lewden unit with combined Type 1+2 and chunky fuse carriers, special order only and over £300 with the VAT. I'm not lining Kirsty's pockets as I think this fiasco is mostly her fault.
Yes, my thoughts exactly! Just been looking at a few prices.
I mean Im all up for improved safety where possible but the cost of all these new requirements are adding up and up
Why are they not readily availiable
I bet next to none actually get fitted when they are supposed to be in the domestic market
Reply to Type 1 SPD and over head lines in the UK Electrical Forum area at ElectriciansForums.net
