Type D RCBOs | on ElectriciansForums
Discuss Type D RCBOs in the UK Electrical Forum area at ElectriciansForums.net
J
johnnycash126
Dear all,
I have to protect a 13 amp ring main which is currently protected by a type b rcbo.The circuit is going to be used by step down transformers from the US.Notorious for tripping on start up.I thought a change to a type D rcbo would cure this,however neither MEM or Crabtree make a type D RCBO.This makes me think that perhaps im not allowed to do this.
Anyone any experience of this?
Do you have to have an RCBO, I would avoid one of those at all costs and try to design the circuit so it does not require one, they are fine in their own right but for a Transformer? hmm how about no chance unless the earthing requirement or enviroment means one has to be used.
Will changing the type of rcbo from a b to a d inter fear with the disconnection times? I would have thought that the best bet would be to feed these transformers from a dedicated circuit specifically designed for this type of use, sounds like someone wants you to do a cheap fix which probably isn't safe
Dear all,
Anyone any experience of this? Can I then replace the type B rcbos with type d MCBs?
you have been a member for 3 and a half years so I assume you are a competant spark yes? that said we are now going down the inexperienced route, what a silly question your last post was, think about what you said and then you will see what I mean.
The americans are coming.And they bring step down transformers for their equipment.ie hairdryers,tongs etc.Historically,they will trip our type B MCBs.Now we have anew installation with type B rcbos. Again,I expect the breakers to trip under starting current.
you have been a member for 4 and a half years so I assume you are a competant spark yes? that said we are now going down the inexperienced route, what a silly question your last post was, think about what you said and then you will see what I mean.
Dont assume.You know what that makes.I was an electrician im now in a different role.
Even so mate an rcbo provides overload and earth leakage protection so if its just inrush thats tripping your rcbo changing it to a cb of the same type (b,c,d) wont make the slightest difference
DIY alert team
  • [ElectriciansForums.net] Type D RCBOs
Reply to Type D RCBOs in the UK Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
