Guest viewing limit reached
Type of washer Hi Team,
I have a leaky radiator as it washer must of got damaged when it was fitted
Anyone know what this washer is called? And where I can find a pack?
It has a chamfer or bevel to it
Outer diameter 23mm
Inner diameter 20mm
Please respond if you know the answer to this question rather than alternative responses
Thanks in advance
Type of washer to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Type of washer plumbing advice
Plumbers Forums
dwaindigital,
