Types of crimps. | on ElectriciansForums
Discuss Types of crimps. in the UK Electrical Forum area at ElectriciansForums.net
If you are talking extending ring final 2.5mm or lighting 1.5mm circuits i often use ideal wire connectors similar to the wago ones and inclose in a wago type enclosure?
I feel they offer a cleaner connection than that of a crimp.
if i have to do it , then insulatef through crimps. heat shrink each joint, then over heat shrink or self-amalgamating tape over the lot.
Reply to Types of crimps. in the UK Electrical Forum area at ElectriciansForums.net
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
Went into an MCCB, terminated very nicely thank you very much, however it was just me doing some training with crimping. 'introducing extra point...
