Types of crimps. | Page 2 | on ElectriciansForums
Discuss Types of crimps. in the UK Electrical Forum area at ElectriciansForums.net
They are commonly called ''Butt Crimps'' or Through Crimps''!! You will need a half decent ratchet crimping tool to make the joints maintenance free. Do not use those pressed flat plate multi function jobbies you get for a couple of quid, they are next to useless and will not give you a sound crimped termination....
That is what you wanted wasn't it?
Surely you know what crimps to use for what cable!!!!!!!
Jfgi.
Google is your friend mate. Try RS site,or a wholesaler.
Im sure I'm capable of performing a Google search for 'crimps'. I've used a lot of crimps before and was wondering what ones are used for household mains. If you don't want to help then why even say anything? :rolleyes2:
Its not something I was planning on doing, I was just wondering about it.
Thats the problem on this site (and why I don't come on here much anymore) you get shot down as soon as you ask something.
Theres some people who do genuinely help though, thanks Engineer54.
Why wouldn't you solder and heatshrink though?surely that's the best way in domestic stuff as generally your using single core cable which I've found generally don't crimp as well as multistrand stuff,where near enough everything is crimped on in industrial applications.
If the solder gets anywhere near melting point you've got way more problems elsewhere before that!
Very true :D, my point is though that it's pretty easy to melt solder. You can melt the stuff with a hair dryer! But it's pretty damn hard to shift a well crimped butt connector. If crimped correctly, a single butt connector should take the weight of a heavy guy swinging on the cable long before it gives way!
Reply to Types of crimps. in the UK Electrical Forum area at ElectriciansForums.net
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
Went into an MCCB, terminated very nicely thank you very much, however it was just me doing some training with crimping. 'introducing extra point...
