Types of installation | Page 2 | on ElectriciansForums
Discuss Types of installation in the Australia area at ElectriciansForums.net
O
olsonn
Does anybody out there recognise this type of installation. I have never come across anything like it before. I was doing some work on a flat yesterday that had a few problems. The incoming water pipe was not bonded and the earthing cable on the gas pipe was not attached. The installer had also obviously had some problems with cable lengths and had put the tails from the socket ring circuit on 2.5mm into a JB and had then taken a single 6mm cable into the CU. Has anybody else seen this method used before and does it meet the regs. I was going to replace this with 2 seperate 2.5mm tails
You’re a brave man!
I know E54 slated it but I've seen worse. I’m one of those weird people that likes split concentric.
I've seen a lot worse too. That's the thing about using concentric cables, they need to be terminated in a decent manner, and very few these days, seem to be able too!! On the rare occasions we've had concentric cables run in on my projects, they have always been terminated with heatshrink purpose made trouser breakouts and sleeving. But i've seen some perfectly good amalgamated tape and heatshrink sleeve terminations....
Reply to Types of installation in the Australia area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
