UFH connection to hortsmann programmer | on ElectriciansForums
Discuss UFH connection to hortsmann programmer in the Central Heating Systems area at ElectriciansForums.net
G
gmpiper1
Hi guys ive got a question for the more experienced out there! Ive wired up an UFH system with two manifold one for upstairs and one for down... all wires have been pulled to the immersion cupboard upstairs.. ive run 5core to each manifold and also to the boiler from this point.. Line nuetral and earth are taken from this point... my question is how do i connect the UFH to the programmer to shut the manifolds down??
your manifolds will have their own stats for each room on each floor also they will have their own valves to open and close independently you could fit a tpn isolator at the maifolds for isolation
Reply to UFH connection to hortsmann programmer in the Central Heating Systems area at ElectriciansForums.net
Certainly is!! And another thing .......... On the old Hive receiver the relay common is a separate terminal, whereas on the new Hive presumably...
I think that's the point I was trying to illustrate. If volt free contacts on a device on one supply are switching mains voltage coming from...
