UK LED Xmas Tree Light Transformer Replacement | on ElectriciansForums
Discuss UK LED Xmas Tree Light Transformer Replacement in the Electrical Tools and Products area at ElectriciansForums.net
CraigC
Reading, UK
Hi, DIY’er here.
I need a replacement transformer but can’t find the exact model required anywhere.
It is Golden Power GP-SW120DC0700(UK)
Input/Pri - 220V-240V - 50/60Hz
Output/Sec - 12V - 700mA 8.4W
Please can anyone help or suggest an alternative model that may work.
Thank you
If you are not bothered about the type of connector on the adapter, and you are happy to splice the output of the adapter directly to your christmas lights (or cannibalize the adapter you have and fit the connector from that) then you could use any 12V DC mains adapter capable of supplying 700mA or more. A 1Amp rated one would also be fine.
e.g.
or
You can find adapters that include a set of different connectors, but these tend to be jack connectors rather than for 2-pin christmas lights.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to UK LED Xmas Tree Light Transformer Replacement in the Electrical Tools and Products area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
Interesting. Sounds unusual since it seems it was very lightly loaded. Not much you can do I suppose other than buy a replacement unit. Unless...
