Un-usual 3 phase problem | Page 4 | on ElectriciansForums
Discuss Un-usual 3 phase problem in the Electrician Talk | All Countries area at ElectriciansForums.net
Tony, I,ve a client who is splitting an old works into a couple of ind. units with individual office units upstairs. Your info leads me to believe that each office would have to be metered individually to comply. Correct? He intends to include costs in rent which would be approx not exact.
Start this as a new thread, otherwise
Well this thread really put all to the test. The latest update is after googling my pc to death i came across this site which has given me a lifeline to recover my sanity. not the best option but not far away. 3 Phase Electric Prepayment Metering
I would like to thank all that put forward their thoughts on this one, it was appreciated, and some good points raised that i would not have thought of.
will also let you know the outcome. good or bad.
Terry
Just seen this thread but sorted out similar problem, with light industrial unit, solution via Matrix Metering this morning.
not cheap but more simple than using 3 single phase card meters 2 415v relays and a 3 pole contactor !
Coin operated timer and contactor
The maximum amount landlords or “resellers” are permitted to charge for gas or electricity is the amount they have paid for it, plus VAT at the appropriate rate
If however you are selling heat not power dose this apply
gaz
I used to hire our village hall on a regular basis. The hire fee included heating be it summer or winter.
The only thing that wasn’t included was the barman, opening the bar was extra!
Reply to Un-usual 3 phase problem in the Electrician Talk | All Countries area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
