Unbiased info on Solar panel and ancillary equipment | on ElectriciansForums
Discuss Unbiased info on Solar panel and ancillary equipment in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
mets
Trying to put a package together to install solar panels in my own house.Trying to get an unbiased account of best quality equipment on market
Trying to put a package together to install solar paneels in my own house.Trying to get an unbiased account of best quality equipment on market
It is not quite that simple, each system has to be designed for each situation.
It would be a little like saying which is the best car, the answer should be a Rolls Royce, but then add I do 1000 miles per week so can not afford to run it at 8mpg, and then saying I have to carry 6 passengers at times, if you see what I mean.
Reply to Unbiased info on Solar panel and ancillary equipment in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I wish I needed a solution to me keep needing get batteries out my 6m boat!
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
