Under cabinet kitchen lighting | Page 2 | on ElectriciansForums
Discuss Under cabinet kitchen lighting in the UK Electrical Forum area at ElectriciansForums.net
Gazthesparky
Glasgow
Hi I've a customer that is wanting under cabinet lights installing in there new kitchen.
Normally I install Fluorescent fittings under the wall units but I'm wandering if anyone fits led tape I'm thinking of installing cool white along the entire length
Has anyone fitted led tape before ? I'm worried that the self adhesive tape will peel off over time
has as anyone got any recommendations of product LED tape or otherwise
Cheers
I have used the self adhesive tape LEDs with success. It is easy to add another strip if the first row is not bright enough. Had some installed for over a year and the tape is still stuck well despite a nearby kettle. I do add some small plastic fittings to make sure they cannot fall off. It can be fiddly to install as I solder it rather than using the clip on connectors which I have difficulty getting to work reliably. Cool white can be very clinical, warm white can appear dirty white, it depends on the colour of the tiles and the customer. I have installed a strip of cool alongside a warm strip for a middle colour.
Reply to Under cabinet kitchen lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a smart lighting system for ambient lighting in a "traditional" kitchen dinning room it's a big area. I want to be able to put...
Thank you for your quick and excellent response - I hadn't thought about the cables changing over time. I'll replace all three. Thank you once...
