Under cabinet strip lighting, Upgrade to LED | Page 2 | on ElectriciansForums
Discuss Under cabinet strip lighting, Upgrade to LED in the UK Electrical Forum area at ElectriciansForums.net
Stephen Waterworth
Hi
I have under cabinet strip lighting. The old 2 pin lighting. I want to buy LED. Question . Can I just use the same powere cable that I used before. I have enclosed some photos . If anyone can advise , it would be much appreciated
Steve
[ElectriciansForums.net] Under cabinet strip lighting, Upgrade to LED
would you happily bury a twin flex in a wall at a depth of less than 50mm ?
The cpc is not there to protect you if you drill through it although it has the advantage that the protective device will trip should you drill the line and cpc together.
the first post showed a twin flex feeding a mains fitting probably a class2 ,the flex appears to be buried in the wall ,IMHO this is bad practise, the t&e should have been brought down back of cabinet into a jb and connection made in there .that's all
my first instinct last night was to say to the op chop off end of old connector and replace with new connector as i didn't think they were compatable, however i thought i would get slated for that so chose a different approach, but that's what i would have done in my own house;)
I think that's the best option in the circumstances. As long as it is done in a decent fashion. To the OP: don't twist and tape the wires :)
No but cable is already in situ.
This is where I was coming from.
That's the way most of us would I'm sure, was likely a kitchen fitter that did it!
Reply to Under cabinet strip lighting, Upgrade to LED in the UK Electrical Forum area at ElectriciansForums.net
If you google '4nway led driver' youshould find something suitable. As mentioned make sure the driver is rated higher than the wattage of tape...
Thank you for your quick and excellent response - I hadn't thought about the cables changing over time. I'll replace all three. Thank you once...
