underfloor heating do i need a CPC-Mesh | on ElectriciansForums
Discuss underfloor heating do i need a CPC-Mesh in the UK Electrical Forum area at ElectriciansForums.net
london
just checking the regs 753.411.3.2 which state i need to use a conductive mesh connected to the CPC of the circuit.
I am installing a flexible heating mat from Warm Up in a kitchen and i dont see any mention of the mats needing a conductive mesh needing to be installed??
Mesh usually incorporated within the heating cable itself. On some the cold tail is just standard flex, so not apparent as such, but the heating cable itself normally includes a braided earthed outer core. Follow MI's and all should be fine. Usually fit Prowarm but should imagine warmup would be similar. Give Warmup a bell if you're worried.
Reply to underfloor heating do i need a CPC-Mesh in the UK Electrical Forum area at ElectriciansForums.net
The instructions tell you to test the insulation and you already know from the result of the previous test that the L and N are not insulated from...
davesparks
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
