Hi, ok I half dont want to ask this question as it doesnt sit right but Id like your opinions.
Installed a heating matt and after the tiles went down I did my final IR tests and there is now a problem between L-E at a reading of ~22ohms. The reading between L-N is still normal at 43ohms, correct value from the manufacturer. Now then what is going to be the main problem with me disconnecting the mat Earth from the main earth and letting it run like this? Problems i see are possible arcing causing further damage to the matt thus totally ruining it, possible electric shock but not sure as porcelain tiles arent known for there conductivity values.
Ideal situation is to rip the floor up and replace the matt but the tiler is denying its his fault and not going to pay for this, neither is the customer and im not also, so who foots the cost for this.
Anyone had this before?
