E
electromonkey
Hello all
I am not ashamed to admit that I have been left scratching my head over a central heating system that I have attempted and failed to wire correctly.
There is a combi boiler supplying a ground floor under floor central heating which is broken in to three zones with a stat and manifold per zone. There are then rads on the first and second floors. The rads and underfloor are supplied by two motorised valves.
I have the wiring diagram for the installation of everything and have checked and double checked it so I know it is correct in relation to the manufacturers instructions. Where the wheels come off is where I have a four core and earth going to the programmer for the under floor heating, a three core and earth for the radiator programmer and a twin and earth back to the boiler for which I have no wiring diagram. The wiring instructions for both programmers have no instruction regarding this type of central heating system. My customer insists that the programmers are the correct ones. I have phoned the tech support for these programmers who basically told me that I would need to "work it out" to get it to work!
I have blown 2 2.5A fuses in the boiler already and am not fancying having to replace the pcb so is there a wiser person out there who can help me? Do you think the programmers may not be compatible and if not could you recommend ones that are please?
Thanks in advance.
Electromonkey.
Thanks in advance.
Electromonkey.
