Underfloor heating wiring connection plug | on ElectriciansForums
Discuss Underfloor heating wiring connection plug in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
UK
[ElectriciansForums.net] Underfloor heating wiring connection plugEa
TL;DR
Hello all,
I am wondering if someone can provide me with some advice. I have had underfloor heating installed and there is underfloor heating wiring left behind a socket. What type of plug can I use to connect the underfloor heating wiring to. I have attached a picture for all of you. Thank you!!
Unfortunately I had someone do unfinished job. Floor and underfloor heating fitted and its just the thermostat and that wiring in the picture left. I am now looking for advice as to what type of plug/connector to use with that black underfloor heating wire. I would appreciate any advice.
thank you
If, as I suspect that is electric underfloor heating there should also be a temperature sensor bulb/cable somewhere adjacent to the power feed, if this has not been put in, you will have all sorts of problems trying to control the heating. What make is the UFH, do you have a specification or instruction manual for it?
I suspect the floor tiler has installed the heat mat and just left it like that pending the OP getting a sparks in to complete the job.
As per previous post, doesn't look like a floor sensor cable in the photo.
It needs testing properly to make sure it hasn't been damaged during installation, something a sparks will do before energising, not to mention and isolator and programmer/thermostat controller.
Reply to Underfloor heating wiring connection plug in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
T
Electric underfloor heating onto concrete floor. I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which is...
Teign Tiler
T
Thanks. Maybe I should of said favourite! The Honeywell sounds good. I did have one of these stats a few years ago but the software was faulty...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
