Underground cable to workshop | on ElectriciansForums
Discuss Underground cable to workshop in the UK Electrical Forum area at ElectriciansForums.net
skinny
Hi
I am planning to put a cable out to a shed to setup a workshop in there. I use a lot of wood working tools (band saw, lathe, planer thicknesser), plus welder and grinders. Ill also want a lighting circuit. All single phase. The cable has to go about 10 m underground and will go under a stone track. the track gets occassional agricultural traffic.
I dont plan to do the eletrical work myself but im trying to work out the safest most practical way of getting the cable from A-B. I wnt to inform myself before I get prices to get the work done and to work out what donkey work I can do myself.
I ve got a heap of questions and any advice would be most welcome.
How deep should my trench be?
What should I back fill with? we are on a hill and when we hve heavy rain there can be a bit of surface water running down the track. Could sand cause the trench to act like a drain?
Is it a good idea to use some form of conduit underground and if so, what?
what type of cable would be best ? Ill get the electrician to specify exact thickness but it would be useful to know what it be likely to be.
Would it be a good idea to get an earth spike?
Thanks in advance
Skinny
Hello Friends,
It is not particularly hard to run underground cable to a detached garage or other outbuilding, especially if you have some basic wiring experience. If you have no experience, then, please take advice from a good electrician other wise it will be a big risk for you.
Thanks and Regards,
Steven Brooks
[ElectriciansForums.net] Underground cable to workshophope you can see the image clearly
I think the key he is "under a track used by occassional agricultural vehicles" and thus deeper PLUS mechanical protection would be a minimum.
As others have said get a couple of sparkies round and see what they say but I'd say that the depth should be greater.
I would say the depth will need to be at least a metre, with a loose top surface that won't distribute any weight, and the promise of a tractor or two "me lovers"!! (sorry couldn't resist). The cable needs bedding in on sand, it needs a cable tile and warning tape.
However with the kind of loads you describe you will need to consult a spark as there are quite a few calculations to be done to size the cable correctly!!
Hi
Thanks in advance
Skinny
How far are you willing to go, to make this cable trench suitable for it's environment?? I get the impression that you would like this cable trench to also act as a drain to take away a certain amount of this surface water during heavy rains?? That can also be achieved, but as i say, it very much depends on how far your willing to go in as far as work and cost investment.
Reply to Underground cable to workshop in the UK Electrical Forum area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
