Underground CCTV cable | Page 2 | on ElectriciansForums
Discuss Underground CCTV cable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Your main problem is you will only be able to use analogue cameras, as IP & HD wont work over this distance without boosters.
Normal baluns wont work either....So you have 2 choices, active driven baluns. Personally I would use a Encrypted Videomitter at around £90 plus long range antenna....Alot cheaper than digging up the ground.
sound good mate plus future proof, but he will still need power there
So no ducts, so there will be no upgrade or repair options avavilable so you are looking at an installation that has no longevity,
I wonder what the client will think when it goes wrong and he is told his driveway will have to be dug up to effect a repair or is the client expecting the impossible with no budget to match
A disaster in the making from what I can see
You'd have to be bonkers if you are not going to use ducting.
Reply to Underground CCTV cable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I've been fitting CAME gate kits. They are very adaptive, have intercoms, keypads, fobs, autodialers entry exit. They also do a lot of wireless...
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
