This thread titled "Underspecifying an inverter" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
They must have put the (optional) 16 A limit on. I'd be suprised if the 4000TL would limit like that otherwise:)
why not?
it's limiting at the maximum output limited for the inverter that's set as standard, not 3680W, so is exactly what I'd expect it to do.
You are of course correct. it an be set at 3680W manually (or any other figure) so I was just suprised to see it so flat topped at exactly the specified output.
Reply to the thread, titled "Underspecifying an inverter" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
