Understand pricing of a job - labour and materials | on ElectriciansForums
Discuss Understand pricing of a job - labour and materials in the UK Electrical Forum area at ElectriciansForums.net
East Midlands
Hi, I wish to get a rough estimation of how much a job should cost considering the UK:
Supply and install 44 Led downlights in ceilings
Rewire 9 of these downlights in a single room after changing their position
Move a single switch from outside a bathroom to inside replacing the existing light with a bathroom light and pull cord
Change an upside down socket to the correct way round
Replace 25 sockets with normal white sockets
Replace 10 switches with normal white switches
Install 3 wall lights
Install an RCD
Earth the boiler
Run a test
I would be interested to know man days and approximate range of rates.
Any guidance much appreciated
[ElectriciansForums.net] Understand pricing of a job - labour and materials
Impossible to esitmate without a site survey. 44 downlights in ceilings - all depends on what where and access. Is this new circuits, or using existing circuits.
Is ceiling void all accessible, are there floorboards, or is it T&G sheeting (horrors), or tiled, carpeted. Is there furniture everywhere, will the ceilings be down or up.
Most of the rest can be guessed, except for
Install RCD, for what?
Run a test, what sort, of what?
turn on a switch and see if the light works (functional test), or an EICR,
Earth the boiler? Isn't it connected to the mains?
So much to know, cant guess.
If I am supplying ALL the materials based upon your job list ÂŁ4600 all in , I have allowed a bit extra for a brand new consumer unit not just a stand alone rcd and I have allowed for new bonding in my price.
Hope this helps with a rough idea for you
(you supply the wall lights)
Using existing circuits AFAIK. Ceiling void all accessible - no issues with accessing lights as they are replacing existing spotlights except for one room where existing 9 lights moved around and rewired. No furniture.
RCD not connected to fusebox so reconnected / replaced
Test is EICR
Boiler was connected but required earthing as not done
Thanks, that's fantastic. Electrician's certainly are expensive these days
What so you mean when you say the RCD is not connected to to the fusebox?
Photos always help as well, but as above, you are going to need to get someone round for a quote.
Fair enough. All that was communicated to me was the fusebox didn't have an RCD or an RCD needed connecting. Anyway, if that doesn't make sense maybe there was a breakdown in comms. Never mind!
OP, looking at your list of things that need doing it looks like you have had an inspection (EICR) on your property maybe?
Install an RCD
Earth the boiler
Run a test
Impossible to give an accurate cost. At a very rough guess ÂŁ4400 including all materials.
Reply to Understand pricing of a job - labour and materials in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
