I had been sent on the NIC Solar PV course last year to learn how to test the DC side of solar installations as my company are testing solar panels in social housing. Due to obvious circumstances the testing work has only started this week and as I completed the course a year ago i'm struggling to fill out the documentation for periodic verification. Therefore I have a few questions that I need help with before I continue:
On the PV array test report is the string over-current protective device a fuse for each string? Or do I instead input the protective device for the AC side? i.e. 61009 type B 16a 230v
Same for the wiring. Is this the solar cable (PV1-F) or the AC wiring? What about earth? Is it n/a for DC wiring with no earth?
Earth continuity - is this referring to equipotential bonding?
I don't have access to any of the original specification sheets for the panels or inverter, so I can't fill out this section of the form. (What do I do?!)
Do I need to use Solar PV system inspection report for periodic verification? If I do then how do I tick 'Array frame correctly fixed and stable?' without a scaffold to check this?
If anyone has any help or guidance they could give me it would be much appreciated, thank you
