Unfused spur in radial circuit from DB? | Page 2 | on ElectriciansForums
Discuss Unfused spur in radial circuit from DB? in the Australia area at ElectriciansForums.net
UK
Can I use an unfused spur direct from the DB on a 20A 2.5mm radial?
In the BGB it says you can on the 4mm radial but it isn't clear if you can or can't on a 2.5mm radial?!
Thanks.
Reply to Unfused spur in radial circuit from DB? in the Australia area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
