Unidentifed Cables from Main Supply | on ElectriciansForums
Discuss Unidentifed Cables from Main Supply in the UK Electrical Forum area at ElectriciansForums.net
UK
I have recently moved into a new house and had to reset the breaker after a bulb went. When I was crawling around with a torch, I noticed some cables (Red, Black, and Blue-ish/Green-ish) leaving the main supply and running into the wall without going through the meter or the consumer unit.
[ElectriciansForums.net] Unidentifed Cables from Main Supply
Is this normal? Is there a second meter somewhere? Shared supply?
New consumer unit was fitted about 2 or 3 years ago.
I haven't been into the foundations yet to have a look but I thought someone here might have an idea of what they are for.
Thanks.
What sort of property is it, Terrace, Semi, Detatched?
Was it part commercial at one time, maybe a shop at the front?
Looks like they may have been fastened to the wall lower down but have been lifted up by whoever fitted the new Consumer unit.
Ring your energy supplier, they'll be able to look on the database and see if there's 2 meters registered to that address.
1960's semi-detached that has only ever been residential. Garage is detached and fed from one of the breakers on the consumer unit, so I know it's not that.
The cables are quite tight so I assume, as you have, they were moved (given the white paint) to fit the new consumer unit.
Not sure, and I don't think I would get anything more than 'I don't know' if I asked.
Is it normal for semis to share electricity supplies? The house is in a large development and not out in the sticks.
Get tapped into that.....free leccy! ;)
Seriously though I’m surprised the DNO has done it like that as it’s really open to abuse! At least they should have used concentric cable, that would be difficult to splice into to steal electricity.
Seeing those cables made me think someone already had! Growing some magic green herbs or running a crypto farm...
Joking aside, is it worth me getting someone to investigate this? I know nothing is 'wrong' with my supply but I don't what to be accused of stealing electricity or get a shock off the cables at some point in the future.
An electrician may have a non contact voltage tester, which although not 100% should give an indication of voltage present.
He may also have a clip on ammeter which will show if any current is flowing (power being used)
If these stray cables are not passing through your meter, you’re not paying for someone else’s electricity.... however as suggested, there may be another meter for your property that you do not know about.
New CU 2 or 3 years ago? You might want to check. The test date sticker on the front hasn’t been filled in.
Who should be my first point of contact?
- Electricity supplier
- Network operator
- Electrician
- someone else?
Think I might as well get it looked at given that it will drive me insane not knowing what the cables are for.
An electrician will be able to test it, and possible trace where it’s going.... but would not be able to remove it.
Try your supplier first, but they just might tell you to phone the network operator.
Called my electricity supplier and they confirmed the supply is for my property only and the adjoining neighbour has their own supply.
What's the next step? See if there is current in the wires? Go under the floor and try to trace where they lead?
I do hope this isn't an illegal setup...
If there's no meter on the end of the cables, it will be for the D.N.O to disconnect but you'll need to find the ends to confirm that.
The DNO will want to know that they aren't cutting of someone with an unregistered meter or a legitimate unmetered supply.
As promised here are some photos of the cable from under the floor:
[ElectriciansForums.net] Unidentifed Cables from Main Supply [ElectriciansForums.net] Unidentifed Cables from Main Supply [ElectriciansForums.net] Unidentifed Cables from Main Supply [ElectriciansForums.net] Unidentifed Cables from Main Supply [ElectriciansForums.net] Unidentifed Cables from Main Supply [ElectriciansForums.net] Unidentifed Cables from Main Supply [ElectriciansForums.net] Unidentifed Cables from Main Supply
The first 3 photos show the cable running through a metal pipe and then into the neighbour's property. I assume that this means the guy I spoke to from the energy supplier either misunderstood the question or didn't have a clue.
I discovered a few other 'problems' that I am not overly happy about. For example:
  • A broken cable held together without a junction box enclosure with the earth wound together and a little solder.
  • Junction boxes going into junction boxes, I am not sure if this is a radial or ring curcuit.
  • A nail used as cable management/support.
  • Huge amount a waste cable that looks connected further under the floor. Although it mostly looks like telecom cabling, there are definatly some mains cables in there but I don't know if they are live or dead. Needless to say, I am not touching it...
Having seen the mess of cables under the floor, I am tempted to get a quote for a full rewire of the house. Although it is probably not worth it as everything is working as it should.
TL;DR: The mysterious cables are the neighbour's main electricity supply.
Reply to Unidentifed Cables from Main Supply in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Normally you'd install either a fuse-switch or a switchfuse at the incoming supply position rather than a DB, this gives you some hope of...
davesparks
Issue is certain sizes of cable may theoretically be okay but upon the proper testing when it’s commissioned things like a thing may not test out...
Thanks for the replies, I appreciate it.
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
