Unsatisfactory EICR?? | Page 3 | on ElectriciansForums
Discuss Unsatisfactory EICR?? in the UK Electrical Forum area at ElectriciansForums.net
B
Billwah
Hi there all,
Just had an EICR c/o in my 3 bed house, and got an unsatisfactory report with c2 and c3 observations.
The c3 is an advisory, with the two c2's causing the unsatis overall report.
The CU is 20 yes old and plastic, with RCD to some circuits, and not others. All are MCBs.
Have been advised to either replace CU for metal, containing similar breakers. OR replace RCD and MCB with RCBOs to eliminate the c2 codes.
One of the c2 codes is for no supplemental bonding.
Friend at work is going through his electrician training and thinks the 2 c2's could be c3s.
Any advice as to which is correct would be fantastic.
Bill
There is no such thing as a fire rated consumer unit.
I dunno....Went to this previous year...(mcbs cleaned before the pic was taken) contained the situation.
[ElectriciansForums.net] Unsatisfactory EICR??
Does the cooker circuit have a socket outlet on the plate?
If not It shouldnt really be a c2 because the lighting and cooker circuits are not rcd protected, as it was pre-regulation
Should be c3 with recommendation to upgrade surely
Looks like you've had a visit from the in the van testers. Should've taken half a day at least if done to the letter, t will not have been carried out with the attention they require. From what we can see here though he may be correct regarding the c2 for lack of supplementary bonding. Easy solution is to replace the bathroom lighting mcb for an rcbo.
Reply to Unsatisfactory EICR?? in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
I would add a price for an eicr. they are highly unlikely to put in writing that it must be satisfactory for the order to be placed.
