T
TBarbados
Hey all. This is my first post. I consider myself to be a competent DIYer. I worked for an electrician for two years and have a better than average grasp of UK domestic electrical installations. However, I now find myself in bulgaria and I'm about to rewire my own house but the system of supply is very different here. In the village where i live the supply comes in two wires, overhead on poles from a small sub station, through a meter on the pole and into my house to my cons unit. THERE IS NO EARTH CABLE. in lieu of any earth cable, what they do here is run a short wire from the earth connector to the neutral connector at each socket. this is accepted practice and done everywhere in the country. my question to you is, given the conditions described above, if i use standard 2.5mm twin and earth to wire my power circuits can i achieve the same effect if i simply bridge between the earth bar and the neutral bar in the cons unit? i read somewhere that with this system, multiple connections to neutral are required in case of a broken neutral but it's all quite confusing and i'm just not sure how to proceed at the moment. i'm fully aware that i will need to provide a proper earth using a rod and whatnot out in the garden at some point but i just need a quick fix for the time being as i am currently (no pun intended) living without electricity and right now i cant afford the extra cash to provide what we would consider a 'correct' earthing arrangement. any help would be greatly appreciated. sorry for the wall of post but it seems this BB doesn't recognise line breaks :/
