There's been a few examples of this lately and I'm bloody sick of them. How can LABC issue a completion certificate without electrical certification?
It's just not possible!
If it's happened either someone has lied their way through things or LABC have not got a bloody clue what they're doing and therefore are unfit for purpose.
Anything is possible if you chuck enough moolah at it.
But none of that is the job of an electrician. Yes, I'm in complete agreement that it's a bunch of pants and shouldn't be happening, but it's not the job of the OP to go stringing a builder up, that's what BC get paid for.
I agree but if not him then who? The home owner is the obvious choice but the OP has a more detailed technical knowledge so his input would be understood (and probably ignored) by BC
If that's what you have found on the service what is hidden, you said that you could not get to junction boxes so have they been terminated correctly. A loose connection in one of them and you have a fire on your hands + if its a new build I don't think you would get away with an EICR in needs to be and installation cert that you can not do because you did not installed it (Catch 22), as said its a new install so should be no coding any deviations should be rectified before the installation is put into service. I agree With Trev Get the Builder back
Thought Part P was introduced to stop unqualified builders doing their own electrics. Yeh seems to be working well. :rolleyes:
Hello folks got a quick couple of questions regarding some testing i have recently undertaken.
Im doing an EICR for a friend on a couple of new build flats where the electrics were done by an unqualified builder.
If the install should be done to current regs are things like missing earths at pendants/switchs or no fan isolators a c2 or c3.
Sense tells me a c3 (with a note on the board about no metal light switchs or fiitings) but its a new build where everything should be done to current regs so does that make it a c2?
Theres no chance of connecting the earths as they are burried in a JB somewhere unreachable.
So basically my question is.....if an installation has been completed to the 17th edition when doing an eicr does the install have to meet all the current regs to get a satisfactory result or is it inspected/tested upon its actual condition?
FYI there are numerous small issues that dont really warrant a C2 but at the same time are certainly not up to current regs.
Shouldnt be doing this after the pub, sorry guys :(
I'm sorry mate, but if you think a brand new install, with no continuity on the CPC for a lighting circuit it a C3 you shouldn't be doing EICR's.
Simple answer is code up the C2's & C3's - issue unsatisfactory report with your invoice and walk away.
An EICR is not for new installs, read the regulations they are quite clear about that!
If you did not carry out the work and are only carrying out the testing then you use a full EIC which has seperate places for designer, constructor and tester to sign.
The person who installed it signs for their part of the work and you sign for your part.
However if you have been employed purely to make a list of what is wrong then that is exactly what you do. Go there with pen and paper and write down everything that is wrong, then type it up and submit it.
And as Trev has said, kick up as big a sh*t storm as you can about it!
could not have put it better than that.
Dave, you make an interesting point with which I agree; however in my experience ( more to do with rewires than new build) more often it is an EICR which is done because the "installer" is nowhere to be found. Typically the relevant council official will accept the EICR in lieu of the missing EIC - this because they too are interested primarily in safety. Of course, it also allows for Limitations which you can't have on an EIC.
Now that's an interesting concept for such an awful installation - I doubt very much that the muppet who did the work will willing give their details, nor sign for the design and construction!
Then there will be no valid EIC for the work and building control will have to take action!
The regulations do not, as far as I know, stipulate that a council bod can decide whether an EICR can replace an EIC or not.
I know what is usually done, and what people accept as the norm, but I am not a sheep who just follows the crowd without thinking.
This is the attitude which is destroying the trade as we have known it!
Unusual predicament testing 17th Edt install
brewlab,
polo1,
TrueNAS JBOD Storage Server
