Unvented hotwater cylinder plumbing advice | on ElectriciansForums
Discuss Unvented hotwater cylinder plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Unvented hotwater cylinder Hi,
The invented hot water tank is dripping water continuously. I have tried to top up the air as suggested in YouTube videos by shutting off the hot water outlet and cold water inlet into the tank, opening the hot water tap to let the water out then opened the valve to air in. Have kept the value open for over an hour, however when I turn in the cold water in let and hot water outlet, water starts to drip.
Boiler is working fine, no issue with hot water or central heating. I have attached the PUC of hot water tank and the water dripping in the black thing.
Thank you in advance for your suggestions.
Regards,
Santhosh
Unvented hotwater cylinder to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Unvented hotwater cylinder plumbing advice in the Plumbers Forums area at ElectriciansForums.net
M
Heat pump hot water cylinder Has anyone fit one of these? A hot water cylinder with a mini heat pump on top with ducts for air in and out. Heat...
Matt0029
M
M
Heat pump hot water cylinders Has anyone fit the hot water cylinders with a little heat pump on the top that has ducts to bring inside and outside...
Matt0029
M
