Update to 3 or 4 gang | on ElectriciansForums
Discuss Update to 3 or 4 gang in the UK Electrical Forum area at ElectriciansForums.net
USA
Hello to all, I have property with av2 gang meter socket, the lower unit was connected to the attic but is is now disconnected. What would be best approach to change from 2 gang to 3 or 4 gang meter socket?
I’m not sure that you will be able to find a 2,3,or 4 gang meter socket. Even if you could then you would have to draw a permit and set up a work order for the power company and when you are finished then it will need to be inspected before your power company will hook up your power.
Thanks you for your response, can I install a separate second 1 or 2 gang without disturbing power for the other meters?
Reply to Update to 3 or 4 gang in the UK Electrical Forum area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
