Updating my 1985 Fusebox
L
liamj2003
Hi all,;)
I have included a photo of my fuse box, as Im unsure of the type (name), Question is:
Im aware there is no protection, with as it stands now, I understand I can just break away the front of the fuse casing to house larger fuses but with switches (if this right) and what are these switches called (micro RCDS or something)
Currently I run all my computer, TV etc from a surge protector, but I have recently installed additional sockets, including one that sits mid level directly behind my flatscreen tv on wall (power socket for TV) and obvoiusly this is no longer surge protected so I guess I need to update my fusebox so some sort of surge protection is in place. (is that right)
Any suggestions/help is greatly appreciated!
Many Thanks
Liam
One thing for sure, your not going to get surge protection units, and the RCBOs in that sized recessed CU, Much better to use a surfaced mounted CU over the old CU back box of sufficient size to accommodate the P/Os needs.... Preferably of a make, that has all of it's RCBOs readily available!! lol!!!
lost me Engineer!!! who mentioned the CU was recessed??? look like a standard surface one to me! check the shadow on wall... :)
you been playing a a Nintento 3ds and screwing ya eyesight up lol..
Better to use a Furse surge protection unit fitted into the CU unit, this will protect the whole installation and far more robust than surge protected sockets and extension leads...
Just had another look at the photo, still looks recessed/flush to me!!! Quite common to find too from that era!!!
Best let the OP to confirm then ...surface or flush!!! lol!!!
look at the shadow cast top left. surface, surface, surface. sorry durham. got carried away remembering the film, above us the waves.
hahahahaha!!!
terminology is all wrong i them films!! dive dive dive!!! lol....
Diving Now Diving Now
Submarine Passing xxM all compartments check round for for leaks and report to control room report on extn ---
Submarine about to Return to Periscope Depth.....
Standby to surface
Surfacing Now!! Surfacing Now!!
or the most scary thing that can happen is
broadcast of SHUT BULKHEAD DOORS..... Claxon x 3 and then an aggressive but clear voice shouting EMERGENCY STATIONS x3 FLOOD FLOOD FLOOD
thats scary!!!!!!
hahahahaha!!!
thats scary!!!!!!
and captain larry grayson saying " i told you, SHUT THAT DOOR"
Sorry for delay yes it is surface mounted, not recessed,
So by the sounds of it my TV wont be protected to the same level as it was when it used to be plugged into the surge protector, Ill eventually update the unit to a modern regular one, but cant afford to be too picky about "over the top" electrical protection.
Many thanks for all your answers..
Liam
