Upgrade gas hob to induction hob | Page 2 | on ElectriciansForums
Discuss Upgrade gas hob to induction hob in the UK Electrical Forum area at ElectriciansForums.net
Stafford, United Kingdom
hello, we have recently brought a new build house and we want to upgrade our gas hob for an induction hob, we have already brought the hob which requires 32AMP and is 7.4KW power
our house layout makes it a little tricky and expensive to rewire a new circuit through (which we should have probably thought about in the first place) but we was just wondering whether they was anything else we could do? we have a grill and single oven right next to the current hob, they is also a 16AMP plug underneath the current hob for the igniter - is they anyway of getting the power from anywhere else?
I would imagine that the oven is plugged in and the cooker circuit is spare? It is on 90% of new builds, mines 10 years old and the cooker circuit still does nothing.
Also it will be a nightmare as the sparks have said, new builds are absolutely awful to do anything in. Get the main run of weyrock up will be the best bet
yes we have a seperate switch and the cooker is on its own circuit 32a - i have seen on other forums people suggesting connection to the cooker but i think with the hob requiring 32a it wouldnt be enough power to use both electicals
What is the Power or current rating of the cooker?
Most single ovens can run off a 13amp plug, so it may just be a case of changing the two over, oven into the 13amp socket and the induction hob into what may be a 32amp supply being used by the cooker at the moment, but without inspection it would be impossible to tell, but I would persevere, induction hobs are brilliant, so much better than anything else out there. IMO
Reply to Upgrade gas hob to induction hob in the UK Electrical Forum area at ElectriciansForums.net
N
He hasn't provided any certificates, including previous work. He sends invoices when he needs paying.but no vat registration number etc on...
  • Nessab16
  • Ireland
  • 8
  • 564
Nessab16
N
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
