upgrade of bonding | Page 2 | on ElectriciansForums
Discuss upgrade of bonding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
And what you must also remember is that certain members of the IEE and the NICEIC have fingers in both pies;)
thank for all replies
so if i was to extend a circuit would a note of deviation be fine
also to calculate using the pssc if 6.00 will work will the time be .1sec its a 60Acartridge fuse
Reply to upgrade of bonding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Even if it’s says that the neutral is bonded to the generator, you still are required to install a ground wire from the generator to the transfer...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
