Upgrading MR16 TO GU10 | Page 3 | on ElectriciansForums
Discuss Upgrading MR16 TO GU10 in the UK Electrical Forum area at ElectriciansForums.net
atpm
UK
Hi all,
I have a failed transformer in a bedroom and want to convert all the bulbs in this bedroom to GU10 (4 bulbs) This is so I can use LED bulbs without hassle.
Is there any type of notification needed for this type of work? Can I just get on with it?
Yet people still have not taken it on board. Using incorrect terms is confusing.
I agree with you that MR16 is the dimension of the lamp and the lamp base is GU5.3 but go into a wholesaler and ask for a GU5.3 lamp you are likely to get blank looks, say MR16 and all becomes clear.
Are wholesalers really that stupid that they don't know what GU5.3 is?
MR16 is not clear. MR16 lamps come in GU5.3, GU10, small ES, and small bayonet.
There is no guarantee that when the circuit is tested on the CU change that this will show that the earths have been snipped for an MR16/GU5.3 12v downlight! The continuity may be there at the furthest point on the circuit but the lamps in question may have no earth. Suggest this is done with someone who has test equipment and can check properly rather than guess.
Just crack on as long as you feel competant to do so, just check if cpcs (eaths) are present and continuous as sometimes they used to get cut off when selv fittings were installed
And not just the cpc's, the fitting now becomes class 1 and should have an earth tail attached to it to connect to the cpc's.
Reply to Upgrading MR16 TO GU10 in the UK Electrical Forum area at ElectriciansForums.net
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
