upgrading the earth bonding, is it notifiable? | Page 2 | on ElectriciansForums
Discuss upgrading the earth bonding, is it notifiable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
No the part P 2010 amendments don't touch this. Spin is right, Tel is right it is one of them grey areas, and to be honest, if your fitting a larger earthing conductor would the LABC be all that concerned. It may well be one of those times you fit it and do not notify, but a call to the LABC is as Spin suggest the way to go.
yeah, phone LABC and you'll get the response " what's an earthing conductor? we don't have bus conductors any more, is it a necessary piece of whatever?"
Reply to upgrading the earth bonding, is it notifiable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
