E
Eng Majed
Hi every body,
I face probelm during comissioning of one project , and I hope that I will find answer here.
My system is like this:
I have 200Kva UPS feeding 100Kva Step-Up Trnasformer.
this step up tr feeding 3 s/dawn transformers
step/up is y-delta connection
from UPS DP I connect 3-Phase to my LV side of the Tx.
then I connect the Neutral in the Y side of Tx to Ground.
what I 'm facinf now is Inverter Overload
it shows 230 Amp L1,, L2 L3 in UPS Reading 120% over load
then the UPS switch to ByPass.
when it switch to Bypass the reading of the current is view Amps .
the load drawn for the 3-step-dawn Tx is working well (which is cameras)
I calcualted my load which will not exeed 30 Kva.
I don't know why when I switch the operattion of the UPS to the Normal (through Inverter) it shows over load !!??
I did one thing.
I switch off the load of one of the 3 step-dawn Tx. but still the load same 120% over !!
finally you may need to know
UPS Output voltage is 380V
while my Step up Tx input is 400V (suppose to be) 400v/13.8Kv
can some body advice me?
I did one thing.
