sl1210
Hi guys got another quick question.
I am going to change 2 fuseboxes in a house tomorrow. Now the main one under the stairs does all the ground floor sockets, kitchen etc and i will fit a 17th edition dual rcd board.
The second fusebox is upstairs fed from a henley block under the stairs and supplies all the upstairs circuits lights, sockets etc.
Now i was only going to put a 5 way main switch board upstairs because there is only 3 circuits, and probably use rcbo's.
My question is could i put a board with an rcd as a main switch supplying the mcb's, or does it need to be a dual rcd board or rcbo's like normal even if it is only doing the upstairs??
Cheers
Cheers
