Upstairs lighting circuit drawing using 60 watts everything switched off | Page 2 | on ElectriciansForums
Discuss Upstairs lighting circuit drawing using 60 watts everything switched off in the UK Electrical Forum area at ElectriciansForums.net
Aberdeen
Hi,
I have just received an electricity monitor and noticed an anomaly in my upstairs lightning circuit. Basically even with every appliance in this circuit (that i know of) 6 x lights and 2 x extractor fans being switched off the circuit is still using 60w?
Any suggestions whats using this 60w?
Cheers murdoch, i think you may have cracked it. I have 2 mains powered smoke alarms (1 upstairs and 1 downstairs). Also, I can confirm the two of them are synced together but unsure if they are wired or wirlesses linked.
Cheers murdoch, i think you may have cracked it. I have 2 mains powered smoke alarms (1 upstairs and 1 downstairs). Also, I can confirm the two of them are synced together but unsure if they are wired or wirelesses linked.
Do the green lights remain on with all the other circuits switches off?
BTW there is a "thanks" and "like" button in each reply, so please use these!
Yes green lights on both remain on when all circuits switched off. Confirm both are in 'upstairs lightning' circuit.
If the smoke alarms don't feel warm to the touch, they won't be consuming more than a watt or two each. Any more than this and you'd feel it.
Given that you can run a smoke alarm on a PP3 battery for more than a year, I wouldn't expect a mains one to consume more than a watt.
long way off 60w
  • [ElectriciansForums.net] Upstairs lighting circuit drawing using 60 watts everything switched off
OP please can you confirm which monitor you're using? As UKMM says certain types such as the Owl USB can read high / inaccurately on loads of low power factor, as they measure apparent power (disregarding phase angle) rather than real power (what you pay for). Murdoch mentioned the Owl but I don't think you did. UKMM's suggested test is a good one.
Reply to Upstairs lighting circuit drawing using 60 watts everything switched off in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
Ok I’ll try this when I’m down
