Upstairs Lighting Circuit Nightmare!! | Page 2 | on ElectriciansForums
Discuss Upstairs Lighting Circuit Nightmare!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So where has the original feed gone then?
That's what I was wondering. Presumably the cable didn't just fall out of the wall, so is probably still there somewhere waiting to be discovered when it's least expected.
Are you sure it's even isolated?
I removed the part of it the was connected to the CU. I traced every section of the circuit in the loft undid everything and put it back together again knowing where every wire came from and went to. The feed had disappeared (or been cut before I got there).
Reply to Upstairs Lighting Circuit Nightmare!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Very technical :D
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
