View the thread, titled "Urgent help - exam next week- planning and prep 2330 unit 205" which is posted in Electrician Courses : Electrical Quals on Electricians Forums.
T
trainee
hi all,
i have planning and preperation exam on 20th april on 2 way lighting circuit strapper method and ring final circuit with 4 sockets and a spur coming of.
im really struggling. im fine with the risk assessment, but what is really concerning me most is the material list. According to my lecturers i require around 45+ items which include fixures and fittings. i only have 40 items, where am i going short? im not sure if i even got them right
can someone please help me with this, im really stressing out!!!!!
im also slightly confused with the 2 way lighting strapper method, im not sure about the cables to use (basics i know). reason being i was absent for first few weeks and got behind with workshop work. to catch up my lecturers have been signing of my work without actually going through it properly, some of my material list have not been completed properly but been signed off, so now its causing me problems.
so this is what i have so far, here goes:
1) consumer unit x 1
2) main switch x 1
3) miniture circuit breaker 6A x 1
4) miniture circuit breaker 32A x 1
5) ceiling rose pendant x 1
6) ceiling rose battern holder x 1
7) steel wire armour 3 core x 1metre
8) 20mm2 glands x 2
9) 20mm2 banjo x 2
10) Crimps blue x 2 (earth banjo)
11) brass M5 nuts and bolts x 2
12) shrouds x 2
13) 20mm2 locknuts x 3 (1 for consumer unit)
14) cleats x 2
15) 20mm male bush x 1
17) 20mm coupling x 1
18) red rawplugs x
19) No. 8 countersunk screws 1 3/4" x
20) No. 8 roundhead screws 1 3/4" x
21) plate screws x
22) open grommets
23) closed grommets
24) 1 gang 2 way 5A plate switch x 2
25) 1 gang pvc backbox 32mm surface mount x 2
26) identification sleeving brown x
27) identification sleeving G/Y x
28) 1mm2 single and earth cpc pvc cable x (for 2 way i think)
29) 1mm2 3 core cpc pvc cable x (for 2 way i think)
30) 2.5mm2 cable clips x
31) 2 gang socket outlets x 5
32) 2 gang 32mm pvc double back boxes surface mounted x 5
33) 2.5mm2 earth cable x (ring circuit)
34) 2.5mm2 pvc cable brown x (ring circuit)
35) 2.5mm2 pvc cable blue x (ring circuit)
36) pvc conduit black 20mm2 x
37) 20mm spacer bar saddle x
38) 20mm 1 way pvc end round back box x 1
39) inspection Tee joint x 2
40) inpection Tee lid x 2
41) connector block 5A x 3 (i dont know what this is used with, advice wold be appreciated)
the items in red are the ones im not sure about, if you could give me any advice it would be much appreciated,
thanks
PS could you check my ring final circuit with spur if its correct, below is a link to the image.
http://i651.photobucket.com/albums/uu233/trainee_2009/ringcircuitwithspur.jpg
It all depends on what information you have been given.
the information we have been given is we have to learn the material list for ring final circuit and 2 way lighting strapper method and also steel wire armour.
normally in ring circuit dont you add sub main board that you attach a S.W.A cable, what size mcb is required?
Upvote 0
Reply to the thread, titled "Urgent help - exam next week- planning and prep 2330 unit 205" which is posted in Electrician Courses : Electrical Quals on Electricians Forums.
Electrical Courses
