View the thread, titled "Urgent help with domestic supply in my house" which is posted in Domestic Electrician Forum on Electricians Forums.
Baker1988
Hello i was wondering if any one could help me i am doing my level 3 at college and have a bit of knowlege but not loads the problem is i woke up this morning and my electric wasnt working i checked the meter and every thing seems fine then i checked the db and it had power too it if i turn all the mcbs off and then turn the 6 amp lighting on the light will work if i tirn another light on the first light goes dim and so does the second light if i turn another one on every thing seems to go off like some sort ov voltage drop problem so i got my multi meter and checked how much voltage was coming in and it read 201 volts and then i turned one of the lights on and tested it on the incoming supple and it went down to 156 volts then i teturned another light on and tested it and it said 78 volts does any one know whats wrong any help would be great as i have never seen this happen before
I recently watched a jointer doing a breach joint. He originally trained at the same place as me and by the same guy. We were laughing when he showed me the plastic cages used for separation and the mechanical connectors now used. Both he and I were taught to solder the cores. A joint or breach is so much quicker now, but the care and skill needed is still there.
Took me ages to get home with the little sidetrack.
Go out & have a chat with them, tell them your an apprentice sparky & your interested in their job. You'd be surprised how most of them will open up to you.
Await the sarcastic comments asking what you've been messing with in order to create that mess and call them out ;)
Make sure you supply the tea, coffee and biscuits and I'm sure you'll be in good favour :thumbsup
lol...... i like how folk are more bothered about you cutting the seal on the meter rather than the fact that you bypassed the meter....... Quality!! By the way i cut the seals atleast once a week so i can remove the cut out fuse when replacing a consumer unit. Stops me from working live and blowing meself up. lol.
I wonder if your earthing system is pme and your neutral has blown off in the road and relying on the earth as neautral?
Hi sorry for the late reply only just got my internet put back on they did come and fix the problem apparently they was a fault on the neutral wire. They put a tempery supply in for now they cam at around 6pm and the electric was back on by 10.30 pm they would not let me take any pictures but after i brought them a cup of tea they was happy to let me watch i found it very facinating they even talked me through a few thing that they was doing i have never seen a live jointing before and i must say i really enjoyed it. Thank you all for all your help thanks
Not overly surprised that they wouldn't let you take pictures, some working practices are not always in accordance with their own rules! For example most do not wear their visors especially when it is raining as they cannot see out of them! Additionally you could scare the proverbial out of the jointer when your camera flash goes off!
My youngest works live on 11,000 volts, they will do a complete pole change live. To be honest just the thought of it scares me stupid, didn't help when he went on youtube over xmas and was showing us examples of flashovers
All this talk of services reminded me of something a few years back,I was called out to a house where the owner kept getting shocks and things blowing up,first thing was to put a martindale in the socket,this showed p-n reverse,so Iwent to the cu and checked there,wired up ok but polarity still reversed.as there was in my opinion a safety issue I removed service fuse and same again p-n reverse,when I rang supplier a stroppy woman went mad about pulling service,however when I spoke to the duty engineer he wasn,t too bothered,seemed more interested in coming to see the problem.Anyway 30 mins later 1 guy in a van and overalls turns up,sees whats gone on and makes a phonecall then 3 suits turn up and start going mental turns out it was a new service and had been jointed wrong in street,wouldn,t want to be the guy who did that one.the best one though was when a chap called me to a fault on a domestic and all the wiring was knackered,even the tails,he thought he was being ripped off when I advised him that it was unsafe and needed urgent work,as there were kids in the house I pulled the service (the insulation was missing in places on the tails v i r ) and rang the supplier myself,who told me to take the fuse and go as they would come straight out and check.Result they came they checked they took his meter,and told him to get it rewired before they would reconnect.Yes they dont like you pulling a service,but in emergencies or when they cock up they tolerate it,but always with care and correct ppe.
Reply to the thread, titled "Urgent help with domestic supply in my house" which is posted in Domestic Electrician Forum on Electricians Forums.
