G
greyt
I recently had a 3.9KW system installed. I have linked my home automation system to the Inverter to see real time output it reports and I can see real time house consumption.
The house never uses less than 1.1KW/H. At the moment the inverter reports 1.8KW output, I know the house is consuming 1.3KW but 0.3KW is still being used from the national grid.
I am manually working out by using the generation meter readings what the margin of error is on the inverter stats, but my question is I understand the consumer unit has two feeds, the electricity grid and the PV unit. How does the PV power take priority over the electricity grid to ensure that 100% of the PV power is used before the national grid power, or is that the whole point, this isn't expected.
Thanks!
Thanks!
