Silva.foxx I have deleted your post because if I had edited the swearing out etc, the post would not have made much sense by the time I had finished with it.
The thread is back on track now and the op hasn't reported it so please let's move on.
Has far as I'm concerned the questions regarding being up to current regs was a valid question by the guys.
True, my wording was clumsy which left it wide open to the scrutiny which received.
If whoever is moderating here wishes to lock the thread down then pleased do so.
Not a very good picture but I have just been on site and took this. As you can see cable ties are prevalent out here.
I have tried to stop it but it is really a culturally thing as well, so we let it go because all lighting circuits are 2.5mm and power 4mm
Oh also ignore colours, colours are designated by whatever the supplier has on stock, something else over here you just have to walk away from
That would be me at the minute, If you request it I will close the thread but if you wish to continue with it that's fine also.
The good thing sometimes with leaving threads running is that more people offer their opinions which give you a more balanced opinion on your question.
It's your choice mate!!
so if you're busy moderating, we can mosey off down to the forest and set some gorilla traps.:38:
Why on earth would you want it closed? you can bunch your cables if you like as mentioned a couple of times, thereis no issue really, some folk hate it though and some employers would not be happy if it was done, some wouldn't care, this site is for opinions, you will get several thats why it needs to stay open, regarding the foxx, I missed his post where the language was so bad the post had to be removed. I personally have no issue with language, however I know of several long term members banned for it, so he is a lucky boy or he is in with the Mods :38:
You wouldn't do that to me would you Tel!!
Jealousy will get you nowhere Mike:hand:
Didn't some else say it should be locked down ?
I don't mind either way.
It doesn't matter if someone else said it mate, if you want it leaving open then that's all that matters. I will leave it running unless I hear otherwise from you.
I only mentioned closing it as it kept going in circles regarding the questioning of the OP... thats dealt with now and no issue with it staying open if we are not revisiting the same old ground...
As for the tiewrap issue it is not really an issue domestic or even commercial or industrial light circuit demand but where you get heavy loading on installs especially industrial it would be considered a no-no to bunch and tiewrap cables together in such a uncalculated manor, everything from derating factors to mcb's rating etc all start been crucial to design when you are getting larger installs... believe you me that there are those that don't even realise mcb's may need grouping factors applied when running close to rating for long durations...
Tiewraps are acceptable but it is circumstancial and to ensure you are on the correct side of the situation then cable calcs is what should be applicable and not because it makes the job look neater. If you have ever removed a failed or warm breaker and noticed a circular heat damaged patch on the side then this is often to do with poor design and not mcb issues...same principle different context.
Certainly not in with the mods... the language was slight... even my church-going nan wouldn't have slapped me down for it. Speak up and you get muted!
CT13 (Are you a Kent man!!!!)
Bottom line there is nothing stopping you ty-rapping your cables together if you want to, and as long as you are happy that there is no degradation of the current carrying capacity you ty rap as your heart is content.
Ty rapping is a modern thing, I would have had my back side rimmed if I ty-ed cable together, but now a days circuits are tapped together in trunking runs which was in my time a no no.
It is just another modern trend, same as running CPCs in metal conduit and trunking, and if that is the way of things then go for it.
I thought the same from the name CT13 lol.
NICEIC don't like it,that's for sure,but the bunching of cabling & the calculation that takes place to calculate the size of cable,are for circuits for that installation,it is not at the distribution board end,& if done practically cable ties are not an issue.It does tidy things up a bit,& like most control panel wiring cable ties are used.
Cheers
Cheers
The calculations apply to the whole length of the cable, you can't just ignore the first 3' of cable!
Cheers
Control panels are a different concept as most of the wiring has negligible load as they are just signal cables and tbh if a control panel is done correctly there is little need for any tie wraps as slotted trunking and cable banding is often used, and yes where the power cables are run and supplies to motors, heaters etc and other loads then the rules still apply although we are getting out of the BS7671 area here tbh.
to add to what dw is saying, we wire a seperate cable to each temp sensor and they draw something like 200ma so sfa when .75 cable is normally used.
most proper control panels use panel trunking so no tywraps would be anywhere near it, door access panels are a different beast, your lucky if you can close the door on some panels you stumble across
Don't think there is a Regulation saying "thou shall not use tie wraps in a CU" but if you think about it there is, or could be a problem with overheating, especially on heavy loaded circuits, in my opinion it's a no no, looks nice but think of the problems doing this could cause. And then you have the problem with testing, trying to identify conductors all neatly tie wrapped up, uugh
DB's in Aussieland are a dream. Cable ducts throughout the boards to prevent individual conductor grouping and looks asthetically pleasing!
Seems like everyone only concerned about overheating factor alone.
As close as you can get in new Regs book and what I think OP meant is a new Regulation (521.200) giving requirements for the methods of support of wiring systems in escape routes.
Apparently to protect fireman. Your cable ties will not comply.
metal tywraps comply
In the properties I own the electrician I use to rewire always allows free space around the conductors as far as is practicable but provides one small cable tie around each of the 3 pairs of conductors of the final ring circuit so that the wiring for each ring circuit is clearly identifiable. This helps him when he does regular inspection and testing for me and any possible erroneous mix up of them. He uses a different coloured cable tie for each frc.
Very strange thing to do, as in domestic properties especially you don't see the length of cable, unless in your houses they are clipped direct on the walls...
Leaving aside stainless steel cable ties for a second, how would cable ties inside a distribution board lead to collapse and entanglement? Surely the distribution board will contain the wiring system!
London
Use of tie wraps and bunching conductors in DB's
Commercial Electrical Advice
Thread Tags
Tags Tags
conductors
CT13,
conrad,
