Using 400v transformer pair to avoid cable runs... | Page 3 | on ElectriciansForums
Discuss Using 400v transformer pair to avoid cable runs... in the UK Electrical Forum area at ElectriciansForums.net
South West
I've been asked to look at putting a new supply to a pool for a heater. It's a long run and there's currently a 1.5mm SWA to run the pump.
We're being asked to quote on a 16A heatpump or similar and they've been told that to up the current carrying capacity for the supply cable they should put a 400v transformer at each end of the run, the idea for this being that this will be cheaper than upgrading the cable and digging up 50m + of playground.
I've never heard of this approach, has anyone done something similar?
It’s within the rating fair enough. Any damage will be exacerbated by the high voltage, terminating takes more skill.
To be honest I’d rather keep things within reasonable limits. With this being outdoors the danger of creapage leading to flashover increases.
Tony, So you doubt you have the skills to make a decent termination? :wink_smile:
Reply to Using 400v transformer pair to avoid cable runs... in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
