Pete - will do - I was struggling to explain it in words !!
I'm back up there tomorrow, so I'll try and sketch it as much as I can, but I suspect the 7 core is connected to the house wiring, somehere under a tiled (suspended ) floor.
Obviously in this case they are equal cross sectional areas, but why must they be.
I can understand it would make design easier, but not sure of the specific reasoning.
Cheers
If they are the same csa the resistance is equal so the load is balanced across the two. Differing csa will result in an imbalance across the two.
Trying to get my head round this and not disagreeing, just like to know the ins and outs of stuff.
Does the resistance need to be equal as it's the overal resistance and csa that the current would be traveling.
Wouldnt the current be greater down the larger conductor than the smaller?
Due to current traveling down the path of least resistance would it would balance itself out proportionately between conductors.
Can I ask why?
Out of ignorance, perhaps. I know the math (area) is OK, but it seems a bit like making a ring circuit from the wrong cable - I appreciate the correct breaker would fix that, but I was interested from a good practice point of view.
From an installation point of view, the house is on a 1 in 3 slope, with the garage floor roughly level with the bedroom ceilings, so replacing the cable is going to be a pain. I guess I'm just checking this wasnt a "just enough" solution to save the grief.
I'm back up there tomorrow, so I'll try and sketch it as much as I can, but I suspect the 7 core is connected to the house wiring, somewhere under a tiled (suspended ) floor.
Not wishing to state the obvious but doubling up may only be possible if you can locate the connections ........ at both ends
Absolutely !! I imagine that ultimately there will be some serious "re-organisation", so we will see. It's one of those houses where nothing is simple :)
The various cables provide supply to a single socket in the garage, the two way switching and supply for the outside light that is paired with one on the house wall, and the power to the garage light. They are stranded cables, and I dont know enough to say if they are 1mm3 or 1.5
The SWA goes all the way back to the consumer unit, and appears to be connected into the ground floor lighting circuit for lights and a 16a fuse for the Socket.
They have decided to leave all alone for the time being, and tidy it up when they have the consumer unit replaced in the New Year. As they have long term plans to turn the garage into a games room, we (ie Daddy) will probably get a new 6mm SWA run up at the same time as the CU is done.
I have put an RCD plug / double socket up there for the time being with 500Watts Max written all over it - just in case !!
Thanks for all your advice on this.
Keithy
Swindon
Using 7 Core Armoured as Twin and Earth ?
keithy1959,
keithy1959,
