using a martindale sb13 with a megger mit320 | on ElectriciansForums
Discuss using a martindale sb13 with a megger mit320 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
dorset
i had to do a hasty test today using a martindale sb13 socket adapter but the megger leads would not fit into the adapter as they seemed to short to make any connection anyone else have this problem.(megger was very similar to the MIT 320)
Reply to using a martindale sb13 with a megger mit320 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Aico use the term Megger on their CU stickers
I've discussed this with the OP directly as we are friends, but for anyone searching in the future, the service manual suggests that this...
