Hi,
I would firstly like to declare that my electrical knowledge is very limited and I would like to apologise in advance if I use the wrong terminology in my following description and questions.
As Halloween approaches I decided to buy the bits to set up a lightning / storm effect.... I found a box that controls the flash of lights to the sound of a CD with thunder (perfect storm lightning effect machine). However, it only seemed to be available to buy from the USA so that's what I did. I am aware that the item is 110v so I will buy a step down transformer. The box will be plugged in to the transformer. I have then bought a 10w 110v led work light which will plug into the outlet of the box. However, the light came with a rounded 16a site plug which I need to change to a USA mains plug... I have a 2 pin USA plug but the cable on the light has 3 wires. Can I safely use the 2 pin plug with this wire and just not connect the earth wire or would that be unsafe? Would I be better buying a 3 pin USA plug and connecting the earth?
The effects box states that it has a max output of 1000w and advises not to connect lights that will draw more than this. Obviously, the light that I have is nowhere near this but my question is this; as the box states it has a 1000w output does that mean that it will be drawing that much from the transformer and therefore accounting for all of the max load that the transformer can handle? When calculating the total wattage do I need to add the 1000w of the box and the 10w of the light or is it only the wattage of the light that I need to be concerned about? The difference in cost between a transformer with a max load of 100w and one of 2000w is massive so I would really appreciate your advice in helping me to understand what transformer rating I will need.
Many thanks, Chris.
Many thanks, Chris.
