Using CPC as live conductor.... ok i know, but... | Page 6 | on ElectriciansForums
Discuss Using CPC as live conductor.... ok i know, but... in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
Had to change a bathroom fan at the weekend for someone and they wanted it to be on a timer, but couldnt as the cable was buried in the wall and wouldn't move etc..
the cable that fed it was a three core flex, I the earth was not being used anyway due to the load on the end etc.
I know you are not meant to use the CPC as a live conductor, but if its flex and the same CSA and you were to correctly identify it with brown etc, would it have then been acceptable?
I didn't do it, but it made me think, oh i so could have used it, but it just seemed wrong. I can understand why you wouldn't do it in twin and earth, but surely where its flex or all conductors are the same CSA and have their own sheathing on them inside the outer, would it have been acceptable or not?
I am going to say not on the basis CPC is CPC and nothing else, any thoughts would been welcomed.
Yes but I still needs a switched live as well as permanent, if I had a bloody three core and earth you are right, we wouldn't be having this damn conversation.
you can take a 3 core and earth from the bathroom light to the transformer and then disconnect the existing 3 core flex from the circuit and re-route to the new transformer, change the LV fan to a Selv fan and it is job done, easy.
Not sure how that works out MDJ ?
He still wouldn't have a SL (or PL) it would be one or the other at ELV ? unless I am misunderstanding you ? It would not be the first time. lol
Reply to Using CPC as live conductor.... ok i know, but... in the UK Electrical Forum area at ElectriciansForums.net
It's the same with any system, if you put poo in, you get poo out!
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
